Results 1 to 10 of 21
Thread: Painting
    Jun 2003
    Launceston, Tasmania
    Painting
    I am thinking about begining to fix up the paint job on grover recently.
    The paint codes I already have (care of REMLR), but is it neccessary to spray everywhere?
    I am going to begin with the cab area. I still have some glue to remove from the carpet that was there, but I was thinking of rolling or brushing in the cab as I don't have immediate access to spray gear, and I don't need to do as much preperation to prevent overspray.
    Is the finish with this kind of painting ok, or does it look terrible?
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Mansfield, Victroria
    hmm they seem to roll and or brush a lot of landrovers in the UK- i have seen various articles in Wrecks to Ritches where they have hand painted.
    I cant see how this can produce a good result but then i have never seen the finished product in the end.
    mick
    Caboolture
    Really depends what sort of finish your talking, if its olive drab youll probably get away with using a foam roller. Mind you ive heard the AJ's used to paint up their beasts with a broom dipped in paint. I used a foam roller for some of mine and it works really well with enamel gloss.
    Mick
    Jun 2003
    That's what I figured as at best the finish wopuld be described as satin, and certainly not gloss.
    I think i'll spray the bodywork, but I reakon that the roller will do the trick in the cab.
    Thanks all [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    1994 Discovery TDi
    Bracken Ridge, Qld
    Re: Painting
    Originally posted by Phoenix
    ...cab area. I still have some glue to remove from the carpet that was there...
    Carpet ? Are you sure you've got a Land Rover there old boy ?
    VladTepes
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Jun 2003
    Yeah, previous owner had glued in a crappy beige carpet with this bright orange glue. I still have't got all of the glue off yet :roll:
    1994 Discovery TDi
    DionM Guest
    As part of the tidyup of the Rangie I was going to give the footwells and loadspace / tailgate innards a touch of paint just to protect the metal and tidy things up.
    As this will be covered by the carpet and the rear storage area I build, I figured that just painting it by hand is probably the easiest optoin. I was going to use some of the rust-inhibitor paint too ...
    However for the tailgate I was wondering if you can buy that thick stuff they line ute trays with etc? Is that a paint-on type of product?
    Jun 2003
    Isn't that some kind of tar or rubber compound?
    1994 Discovery TDi
    Bracken Ridge, Qld
    Yep. If it's what I'm thinking off it's known as 'spray on ute-liner'. Not cheap for a whole ute but if you ask around at a few ute places you never know what you might find out.
    gone
    1996 Discovery 1
    current
    Oct 2003
    Godwin Beach Qld
    painting
    Hi Phoenix [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    If you are using good old "Lusterless Olive Drab" Spraying Enamel it can be brushed on with good results, don't thin that stuff any more than 10o/o or it will run of the surface you are painting , another tip, stir it up VERY well as the pigment and flatterner sticks to the bottom of the can, a good 10 minutes, use a good quality brush 25-40 mm small sections at a time as it dries in about 10-15 minutes
    If spraying thin only 10o/o with general purpose enamel thinners
    regards Rocket :wink:
