Results 1 to 10 of 12
Thread: Blown head gasket? L322 fails.
    Jul 2010
    Sydney/Balmain
    Well 1 month into my L322 ownership I have a blown head gasket.
    From what I have learned this is a rare occurrence with the V8???
    3 days ago I got the dreaded "Low coolant" bing bong from the dash
    Pulled over at soonest opportunity, temp gauge hadnt shifted at all, there seemed to be plenty of coolant still in the exp tank when I bled the pressure off, topped her up and started up..........bubbles and belching of air which increased with revving of the engine.
    Luckily I have a warranty on the damn thing, took it back to the yard that I bought it from...FEW what a relief, no dramas at all the dude says we will have it back to you in 3-4 days.
    ERM your dreaming buddy thinks I.
    Luckily I know the mechanic that will be doing the repairs so I can keep pretty good tabs on whats going on.
    Well the trusty P38 has been resurrected and is busy doing what it does best, Im so glad somebody didnt buy it!
    And I dont want to hear from all you guys with Tractor engines in your RANGE ROVERS telling me I should have bought a diesel............
    NSW SW Slopes
    Would it be prudent to pay to have the other side done whilst its apart?
    Jul 2010
    Sydney/Balmain
    Sure will be pushing for that, seems pretty nonsensical not to do that.
    Adelaide - Torrens Park
    Quote Originally Posted by RR P38 View Post
    Should have bought a V8 diesel . Far far far from being a tractor engine
    Jul 2010
    Sydney/Balmain
    Quote Originally Posted by BigJon View Post
    Just a bigger tractor engine
    That will be on the shopping list in another 5 years when they are in the $30k range.
    Mar 2007
    RR P38
    Not trying to be rude, BUT are you sure it's a head gasket ?
    Failed/ faulty thermostat or the PCV hoses leaking can appear like a HG failure.
    Watery oil is very common example caused by a leaking PCV system, which will also cause miss-fires and codes that a dealer will say is HG failure. These engines only usually blow head gaskets after being severely overheated to the extent that other internal damage is done also.
    Laurie
    Dec 2011
    Toowoomba
    I can remember a mate about 20 years ago that had a 351 V8 engined TRACTOR ! He did it as a dare, when his Massey diesel got tired after about 20,000 hrs and he had a rusty Fairlane---
    So I ask, V8 petrol TRACTOR engines?
    Me? I've an early L322 TD6---- tractor engine? maybe ? with twin OHC, 4 valves/cyl, variable vane turbo, 4800RPM.
    Very sweet engine.
    Jul 2010
    Sydney/Balmain
    Quote Originally Posted by Laurie View Post
    RR P38
    Laurie
    Not rude at all my friend.
    I am open to all suggestions.
    It sounds like you may be correct with your heads up call.
    Had a call from the stealer saying that the mechanic had found a "faulty sensor and a few leaking seals" ?? The stealer is not mechanically literate at all, the mechanic working on it comes very highly recommended by a friend with years of Landy experience........so Im quietly confident that all is well, or will be.
    Hunter Valley
    You cant run the BMW V8's with the radiator cap off as they boil and spew out the coolant.
    Kiwiland
    How about those of us with truck engines in our Range Rovers?
