Results 1 to 10 of 20
Thread: Stereo system for a Defender
    Bracken Ridge, Qld
    I am wanting to install a CD player/radio and 2 speakers into my Defender single cab.
    Sound does not have to be concert quality (it's not a Range Rover after all) but I need to make it loud enough to be heard over normal LR noises. I am looking for a head unit with green illumination. MP3 playback would be great. A reasonable price is important (it might get pinched). Any ideas ?
    MOUNTING: I understand the standard mounting place is above the cigar lighter/clock console between the vents. Apparently there is a special "box" to screw in, into which a standard single-DIN unit can be installed. Where do I get this whatsit ? How is it mounted ?
    (Bugger! Reckon I'm gonna have to move the UHF now!)
    SPEAKERS: Where do you good people (ie Defender owners) have your (front) speakers mounted? On the dash? In the doors ? And what speakers / speaker size is good in that situation?
    Thanks - appreciate it.
    VladTepes
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Jun 2003
    Launceston, Tasmania
    I actually have 2 speakers in the seat box im my series 3, so they are behind your legs when you are sitting.
    Don't know how good they are, because they aren't attached to anything ops:
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Bracken Ridge, Qld
    [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] LOL
    But they do a great job of filling up those strangely speaker shaped holes, don't they?! [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    gone
    1996 Discovery 1
    current
    Jun 2003
    [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] they sure do. At some point i'll attach a casette player to them.
    I don't think that they will be too great because the backs are exposed to the elements. Translation ........... they get muddy
    1994 Discovery TDi
    Defender200Tdi Guest
    Hi Michael
    The standard mounting point for the speakers is under the dash like this:
    Don't put them there, it's about the worst possible place for sound quality & volume, unless your ears are on your knees! Since you have a trayback, you'd be better off mounting box style speakers above and behind you, facing forward. Alternatively, using the standard mounting possition to mount splits works OK as long as you mount the tweeters on the A pillars facing you because the high tones are much more sensitive to direction.
    A copy of the original head unit mounting bracket can be had from Autopro or Strathfields for about $20.
    Paul
    betty Guest
    mine has two speaks mounted in the AC unit, but had the same problem, not loud enough, so replaced the landrover speakers with better quality ones and cut two additional speakers into the head lining at the rear (Defender 130). The whole system now works really well, good sound quality and plenty of volume if needed, (Drown the kids out in the back). running the cables was easy, up the door pillar behind the plastic trim, behind the head lining with the assistance of a bit of patience and an old coat hanger and connected up to the speaker.
    Bracken Ridge, Qld
    Defender200Tdi has nothing to worry about as the left footwell is entirely taken up by 1. The aircon unit (mine's different to his) and 2. The wife's feet.
    So.. no speakers going there.
    He might, however, care to explain WHERE 'above and behind' me there is room to mount speakers ?! It's a single cab. I'm tall-ish (6ft). Not much room there.... :? [img]style_emoticons/<#EMO_DIR#>/sad.gif[/img]
    Oh and betty: Landrover speakers not primo quality ?
    They probably leak [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
    gone
    1996 Discovery 1
    current
    Jun 2003
    I think that he means mount them to the roof above and behind you, but I haven't been in a single cab to see how much room there is.
    1994 Discovery TDi
    Bracken Ridge, Qld
    I assure you there's not much.
    Also what do I mount them in, or on, or to ?
    And what size speakers ?
    And can anyone explain the difference between a 2-way and 3-way speaker to me.
    Ta muchly
    gone
    1996 Discovery 1
    current
    lewy110 Guest
    I fitted new speakers to the county and had to space the left one out as the standard landrover one is really thin and crap. If you have a centre console you could always mount the radio in there. I have a sony minidisc player mounted in my centre console and a remote that screws onto the outside of the console it works well and looks like you dont have a radio.
    With regards to the speakers, 2way a woofer and midrange in one, 3way a woofer midrange and tweeter all in one.
