Results 1 to 10 of 29
Thread: Towing with a heavy drawbar weight
    Hannahandsando Guest
    Hi There,
    We have a Range Rover sport 2008 with air suspension. We are wanting to buy a 4WD camper trailer. We have narrowed it down to an Ultimate (which have very good balance - hardly any drawbar weight) or a Kimberley Kamper. We prefer the Kimberley (we think) but it has a high drawbar weight due to length and position of wheels. We are concerned the air suspension could give us problems, partic when towing off road. All of our friends who regularly tow have Toyotas with coil suspension. Any advice appreciated.
    My camper has a 200kg tow ball weight - due to wheels on the camper being set to the rear.
    I have no issues when actually towing - car sits fine.
    Just make sure your shockies are in good nick.
    Kiwiland
    How many kg?
    Dec 2009
    Ranelagh, Tasmania
    What are you concerns with the air suspension?
    A lot of people on here tow with RRS/D3/D4 without any problems on-road and off-road.
    If the concern is the airbag bursting, it is very unlikely.
    Problems I know of are that the dampers/shocks are more expensive when they wear out. The air compressors can wear out and fail and sensors can give problems.
    Depending on how much work the car has done the dampers/shocks may be due for replacement.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    North Central Victoria
    Quote Originally Posted by Hannahandsando View Post
    Hi There,
    IMHO the rover will be better in all respects - both towing on road and off road. It will level automatically when you hitch up and be fine offroad. Just make sure your air suspension is in Good nick and off you go. Better seats in a rangie than a 200 series too
    Don't listen to Toyota drivers or those who don't understand a rover and fear technology. A properly maintained rover will eat them all for breakfast. Toyota is more than 10 years behind rover technology. My 99 disco has similar roll bars (ACE) compared to my folks 200 series (KSS I think it's called). My seats are better too And a loaded 200 series will use upwards of 25litres per hundred towing off road. My dad uses 33litres per hundred towing his twin axle off road van with his 200 series when offroad
    Dec 2009
    Williamstown, Barossa, SA
    Hi Hannahandsando.
    You say it has a heavy drawbar weight... How much is heavy? If the Ultimate has next to no drawbar weight it might have the habit of snaking... I've always been of the opinion that something with a bit of drawbar weight is better.. If its too much, you could always load accordingly with water, wheels etc at the rear of the trailer..... Let us how you go, and which trailer you settle on.
    Cheers for now, Simon.
    1995 Mercedes 1222A 4x4
    1969 (Now know! Thanks Diana!!) Ser 2 Tdi SWB
    1991 VW Citi Golf Cti (soon to be Tdi)
    'When there's smoke, there's plenty of poke!!'
    'The more the smoke, the more the poke!!'
    Kingston, Tassie, OZ.
    the drawbar weight of the ultimate, t van and kimberley are way under the max allowable for the rrs, you won't have any issues at all.
    jc
    Moruya Heads/Sth. Coast, NSW
    Go for the Ultimate. so much better than the Kimberly, on and off road, regards Frank.
    Quote Originally Posted by Tank View Post
    If you want good offroad, the Tvan is far superior than anything on the market. I towed mine to some unbelievable spots. Track trailer design trailers for the military and they have a gal chassis. No stone chipping. And a quick nights stop needs no set up at all. Open the door and hop in . I had to sell mine last year though . Most regrettable
    Cracka Guest
    I just bought a Tvan a couple of months ago. 145kg tow ball weight, loaded. I'm thinking of putting polyair red bags in the 90 as she squats a bit rear and lifts the front. Tows like a dream though I love it
