Thread: Spares worth carrying for 6x6 and 4x4 Perentie
    RC110 Guest
    Found a good source to get some Perentie spare parts, Is there anything apart from the obvious stuff that would be worth grabbing, any parts that may cause an issue on a long trip ect... cheers
    SW of Geelong
    If you're talking parts specific to the Isuzu, one I can think of is the fuel pipe from the top of the filter housing, the one that's bent around in a circle. Apparently they have been known to crack.
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Feb 2005
    just hop in and drive..........
    give it the once over and a good service, pack some basic tools......its going to take a while before you get to know the car
    i spent 20 years around the army 110 and 6x6, like any car if you maintain them the generally look after you
    Hay Point
    Quote Originally Posted by RC110 View Post
    Don't know what you call obvious stuff but guessing spare fuses, fan belt, radiator hoses, bypass hose and filters (don't forget the sedimenter one on the chassis. Apart from them not much seems to give any problems. Good idea to carry a spare set of wheel bearings and a new hub seal as well as a couple of driveshaft unis. (K5-13XR) fits front or rear on the perentie. Interested in sharing your "source" ?
    Cheers......Brian
    1985 110 V8 County
    Sep 2010
    adelaide
    what the bear said. i also carry rear axels, a tin of fiberglass bog ( radiator). 5 ltrs of oil, motor oil you can use every where else. c clip plyers. and WATER. shes a big radiator if you have to fill it.
    having said all that. my spear parts always seem to go to othere peaples Defenders and countys. not always to be replaced . and some times not even a thank you. but then there is also the odd bottel of red.
    so i do not tend to let on what i have onbord nowdays.
    bugger now i have to fugger out how to delete this post
