Results 1 to 10 of 12
Thread: Disco Suspension
    Caboolture
    Disco Suspension
    G'day all
    What are my options for fiddling with disco suspension if i wanted a lift of maybe 2 inches. Is it just springs and shocks or do you have to get funky with prop shaft angles etc.
    Basically i just want to stop potential diff wacks on tracks.
    Mick
    Pilbara WA
    New sprinds and shocks will get you a two inch lift if you pick the right ones.
    Once installed get a good wheel alighment to make sure of it all and then that's it.
    Well it was for me anyway's.
    Might want some spacers under the rear to, will even it out a bit as Disco's tend to droop towards the back.
    There are two types of people in this world, good and bad. The good sleep better, but the bad seem to enjoy the waking hours
    Caboolture
    Are they the polyurethane spacer thingies
    Pilbara WA
    Thats the one's.
    After my lift the low back end stood out a lot more so I fitted the spacers and it leveled it all nicly.
    1 1/2 inch spacer I think I put in.
    Also stopped it from bumping the fuel tank as much.
    Caboolture
    groovy i was looking at them the other day and i thought they looked the part
    Caboolture
    did you use fixed rate or variable springs. and what brand did you go with
    Somewhat North of Cape York...
    Mick,
    maybe I didn't get you right but if you want to protect your diffs you will have to use diff protectors or bigger tyres. Raising your vehicle's suspension does not alter the ground clearance under your diffs.
    Happy rovering...
    Johannes
    There are people who spend all weekend cleaning the car.
    And there are people who drive Discovery.
    HSVRangie Guest
    Giving the car a spring lift will not increase diff clearance this can only be done by fitting larger diam tyres.
    If you can fit the correct springs to give the lift you want, fitting spacers is a dead lift, no real gains other than increased hight.
    Drive shaft angles will be ok with 2 inches. JUST.
    Castor will be almost gone.
    DONT fit castor correction bushes as these will inhibit supension articulation. Best option is to rotate swivell housings, aprox $200.00 if you remove and refit them yourself.
    regards
    Michael.
    99.87 MB
    We are talking D1 and not D2?
    Slunnie
    Pilbara WA
    D1 from me.
