Thread: L322 TD-6 Gearbox operation
    Feb 2009
    Bondi
    Smile L322 TD-6 Gearbox operation
    Hello again
    I still have a nagging problem with the gear change up and down.on my 2002 L322 TD-6
    It seems to rev way to high before changing gear, in both directions.
    I have replaced the battery, which on a previous thread someone thought could be the problem.
    Three different mechanics have given thee different diognostics.
    One said New gearbox
    Another said Get it flushed
    The last guy said it was the ECU needed to be remapped.
    Does anyone know of a good Land Rover mechanic that could have a look at my vehicle ?
    I would be prepared to travel anywhere in NSW.
    Cheers Paul
    Sussex Inlet. N.S.W.
    The same with mine. I believe this is pretty normal for the gearbox to hunt a bit. Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Manly QLD
    Quote Originally Posted by BRUMMY View Post
    Can I ask, how high is too high? and under how much throttle load?
    As an addition to my reply, I removed the egr valve and it made a hugh difference to where the box changed. It will lock up down as low as 55k/h whereas before it barely locked under 80k/h
    Jim VK2MAD
    '17 Isuzu D-Max
    Aug 2010
    Sunbury, VIC
    Try Rhys at Furious Performance in Sydney - he is a member on here - Rovernova - and what he doesn't know about these boxes isn't worth knowing.
