Thread: Houston We Have A Problem
    May 2009
    Tatura, Vic
    Pulled spark plugs from sons car and this is what I found.
    Not good
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Oct 2006
    canberra
    Not unusual for a falcon. If you do the head gasket use the steel shim gasket not the composite type there fitted to au falcons
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by Mr Whippy View Post
    Not good
    At Least on a Ford it's an easier job if that makes you a little happier.
    But no, it doesn't look good
    Geelong, VIC
    For the last 15 years I've had older Falcon 6cyl's on LPG for my daily drive. XF, ED, and currently an EL.
    All have done a head gasket around the 220-250K mark. Reco'd head, new hoses and radiator and no further issues. XF transmission finally died somewhere over 500K, and I pensioned the ED off at around 480K when my work colleague offered me his well maintained EL wagon for tradein price.
    Whack a reco'd head, radiator and hoses on it and forget about it.
    FWIW - I fitted an engine watchdog to the EL when doing the head as I had O/S relo's visiting that were going to borrow it for a couple of weeks to travel around while they were visiting.
    Thankfully, as it saved the engine about 6 months later when the brand new thermostat failed mostly closed in January peak hour traffic. Managed to keep it under control with heater/fan on flat out but would certainly have cooked it if I hadn't had the warning.
    IMO for $150 its damn cheap insurance...
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Adelaide - Torrens Park
    Quote Originally Posted by 460cixy View Post
    But do make sure you use the AU headbolts, which don't break like EF-EL ones.
    Dandenong Ranges - Victoria
    How does it convert water to fuel?
    Is that part of the $25 eBay 'get 100mpg' black magic the oil companies don't want you to know bolt on parts?
    May 2009
    Tatura, Vic
    You are right about being not unusual to a point. In our family we have owned quite a few E series falcons and all have had head gasket problems, but this is the first one that has blown water jacket to a cyl. All of them, and I am talking about five, have all leaked externally.
    When I came across the first I was amazed, as during my 35 years of swinging spanners I had never seen this. Most cars that I have done heads on, and I reckon it would be over 100 plus prior to the E series Ford, have either blown between two cyl not causing water issues, or blown water jacket to cyl
    And yes they now get the multilayer steel gasket used for the AU .As for the head bolts, I use what the machine shop that does the head supplies me and I have never had issues.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
