Results 1 to 10 of 16
Thread: Oil seal, between gearbox & transfer case
    Sep 2010
    Townsville Australia
    Hi guys,
    I need to change the oil seal between the gear box and transfer case, to prevent oil flow between same.
    Any ideas guys....? It's possible to do without taking the gearbox assy out..?
    Thank you,
    Norm.
    Benmoore15 Guest
    On my 300tdi disco I removed the transfer case while in the car quite easy though I did have a hoist
    Sent from my GT-I9100 using AULRO mobile app
    Northern NSW
    Yes an easy job.There are some nuts inside the transfer box accessed through the cover plate.I have done it must be easy.
    Cheers Will
    Narrogin WA
    Taking the seat-box out gives full access and you can stand inside the car while you work on it. The only hassle with that, is undoing all of the fasteners, which may have rusted together,
    Cheers Charlie
    Yes, transfer case can be removed without removing the gearbox. It can be removed without removing the seatbox, but is easier if you do - provided the fasteners come undone easily!
    Sep 2010
    Oil breatherS...??
    This is probably a silly question, and is probably a very basic question.
    On the oil filler pipe and on the rocker breather there is a tube connection, in the past I have always connected these to a vacuum connection, but it then occurred to me that thi cannot be correct, in that wouldn't the fuel mixture be weakened.....? Any clues Fellahs ...?
    Thanks,
    Norm
    Sep 2010
    Quote Originally Posted by normbourne View Post
    Thanks,
    Norm
    By the way it's a series 3 petrol.
    The connection on the rocker cover goes to a connector on the air intake elbow above the carburetter, the one on the oil filler goes to Positive Crankcase Ventilation valve on a bracket from the intake manifold next to the carburetter, and thence to a vacuum fitting on the adapter below the carburetter.
    Sep 2010
    Oil seals gearbox etc.
    Back to my gear box.
    My efforts to replace the oil seal in situ were in vain........!
    Despite my reluctance about pulling the gear box out, it turned out to be the best move I ever made...!
    When I came to pull out the clutch linkage from the bell housing, it was to discover that one of the pins through the connecting tube, had broken into three parts. I would have been really p......d off, had I put the box back in to then discover that it would have to come out again..!
    Anyway it turned out all oil seals need replacement and the seal on the main shaft, was approaching 5 on the moh scale it was that hard, not surprising really considering that I've never changed it and I've had the vehicle 40 years. But no wonder the oil was flooding past.
    Cessnock NSW
    Another cause for losing oil from g/box to T/case especially in S3 G/box is the main bearing housing can and does turn in the G/box casing, this effectively pumps oil.
    You can stop it by using Loctite or drilling and tapping a hole, screw in a grub screw to hold it n stop it from turning, cheers Dennis
