I have become a fan of SiliconBronze MIG for these sort of repairs.
I know, I know it was developed for welding body panels and other skin work.
And yes I know it wont be a structural weld.
But for cast housings of unknown temperament especially those cast 'whoflungdung' parts with made in China stamped on them.  I have had much better success using the GMAW (MIG) process
- straight Argon and 0.9mm SIBronze wire as opposed to other techiniques.
The other benefit is that it is easily machinable after welding.
I have found if welding up cast using ER70S wire (standard hard wire) the finished weld becomes incredibly hard (martenisite perhaps - or just carbon pulled from the cast into the weld pool) to the point that even carbide tooling bounces.  You can limit this a little with pre-post heat and peening or just use SiBronze
Assuming that is a standard 300-esque housing that has bolts supporting the central section and then the slip in horns, there would be very little load (other than gas sealing and heat cycling) on the broken portion. Clean up on the linisher, tidy up a weld groove and glue it back with the SIBronze would be my attack.
Something to consider if you have MIG and get to play with cast whatevers...
Obviously SiBronze is not a good option if the casting has significantly high structural loads applied to it... but in my experience cast iron/ cast steel is of such low quality these days the above is rarely a problem.
My most recent success with SiBronze was a flogged out hub. The hub nut had been run too loose, and the bearing cup had spun and worn out the hub surface.  Luckily the land was still intact so I had a good depth reference.  Chucked up the hub in the four jaw and dialed it in as best as possible off the good bearing surface. Cleaned up the worn bearing surface to about 1mm above diameter. Then slowly turned lathe while laying beads of SiBronze. Very easy to then machine it back to press fit tolerance.  Effectively line bored the hub with SiBronze.
Worked well and hub now fits up beautifully and spins concentrically on axle.
This saved a hard to replace hub with only a few hours work.  Obviously the SiBronze will be marginally softer than the original casting but I can cope with that risk.
Steve
