Thread: Lifting a D1
    Nov 2012
    Springwood
    Lifting a D1
    Hi guys,
    I'm trying to find a reasonable way to do lift work on my disco. In stock form it is capable of doing most of what I want it to do, but the previous owner has put a 10L lpg tank on the drivers side, which gets caught on a occasionally. Ideally I want something that I can raise two inches to give myself some more room on that side, but can then lower it to standard or slightly lower height to make it easier for my vertically challenged wife to put bubs in and out of the car when she has it and I'm not around.
    I was looking at polyair red series, with a set of terrafirma +2 adjustable shocks.... decent or should I look for something else?
    St Helena,Melbourne
    4.28 MB
    Apart from airbag suspension you cant lift and lower a vehicle on demand so i'd suggest a standard 30-50mm lift and a set of side steps, polyairs are for load carrying and not a replacement for coils.
    Are you sure its a 10l lpg tank ? , would be pretty pointless at that size.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2011
    South Aust
    Diesel / Gas im thinking.
    Crafers West South Australia
    Diesel gas IMHO but probably 17 or 19 litres LPG capacity.
    Nov 2012
    Springwood
    It is only a 10L tank, and yes it is diesel/gas.....
    It really does get in the way though....
    I will have a look at the side steps, which i wanted to do anyway...
    Anyone tried the terrafirma adjustable +2" shocks? What springs would you suggest?
    I wouldn't say it's carrying anything overly heavy, I was thinking something light to medium. I don't have a winch yet, and no fridge, tent is only light and not towing anything
    St Helena,Melbourne
    4.28 MB
    Unless you get lifted springs you wont need + 2" shocks, even most stock shocks work with a 2" spring lift anyway.
    1974 VW Kombi bus
    Nov 2012
    Springwood
    Sweet so just the springs should do the job in reality...
    Thanks guys!
