Hi, LRHydrid 100,
I've a 3.9 V8i which I just converted to LPG they recommend
to use one-range colder and non resistor type NGK Vee-Groove
spark plugs and low resistant stainless steel plug leads
Your LPG installer should be able to advise you.
Because I had a service prior to fitting conversion, am still running
std plugs. however on 1500 Klm LPG check being done next week
and will get leads fitted then.
Will fit "V" groove at next service.
You'll love the diffrence in the back pocket LPG makes [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
Hope this assists,
Cheers!!!
