Results 1 to 3 of 3
Thread: V8 radiator
    Landy86 Guest
    V8 radiator
    Hi guys I've search the forum can't can't find wat I'm looking for
    I need the biggest alloy radiator that will fit in the 110
    I'm running a 6litre chev and need a better cooling system
    Is there some one that custom makes them
    Brisbane, Inner East.
    Quote Originally Posted by Landy86 View Post
    go to Home - Speedway Motors, America's Oldest Speed Shop and select Cooling. Enormous range of radiators, pumps, tanks, etc.
    URSUSMAJOR
    Jun 2010
    Buderim
    you need to make sure that any replacement you have made or buy is the same type as a 6 litre chev - cross flow, down flow or multiple pass. It needs to be matched to the flow rate of the pump. This should give a matched system where there is a min pressure drop throughout the radiator and min vapour content at pump inlet and of course maximum temp drop between radiator inlet and outlet.
