Originally Posted by
Chops
G'day Gareth,
Just plug it all in, and it should be good to go. You can do this without actually mounting it all up in car, but you will need to do the ariel the right way, as correct earthing is important. I'm not sure of the models your referring to, but so long as its UHF and got 40 channels, it'll be fine for what you need. As you said, you have a Sat phone too, so your well covered.
When you've finished installing it, just ask for a "radio check", and if all well, you'll get a reply. See if you can find out where they are, so you can sort of check how well/clear your getting out.
You've also got a couple of forum members down where you are, so you might be able to get some help from them too.
