Any diff specialist should be able to do it.
 Master
						Master
						Im going to order a couple of ATB's for my Puma. I won't be able to install them. Is it a job for a Land Rover specialist (MR Automotive - need to book 18 years in advance to get work done)?
Can a specialised differential workshop do it just as well as a LR specialist? Will they know all the specific settings etc?
Diff Lapping at Kedron fitted my Trutrack
I also got the diff lapped.
L322 tdv8 poverty pack - wow
Track Trailer ARN 200-117
REMLR # 137
 Master
						Master
						Ive heard endless of good reports from the 4wd community about them. A little to far for me, but do able if need to.
Looking at these guys - Differential repairs and services by 1300 Autotrans
How many hours labour were you charged for?
REMLR # 137
What's diff "lapping" ?
gone
1993 Defender 110 ute "Doris"
1996 Discovery 1
current
Basically it is running in the diff with a slightly abrasive paste applied so it wears in properly and with minimal load.
 Master
						Master
						Would requesting lapping (Diff lapping that is :P) be considered best practice when installing an tab/truetrack?
Lapping is usually only necessary on a new ring and pinion, if you aren't changing them (eg changing ratios) then they should already be lapped or worn in. Perhaps if the pinion height changes it might need it lapping.
