There was a dark blue defender possibly a Puma as it looked like it might of had the black saw tooth rims, also had a slim line rack like a Hannibal or front runner on, travelling on the Hume highway this evening at warp speed at 8:30pm
between campbelltown and Narellan road travelling towards the southern highlands
If you are on this site and you are reading this and you were lucky enough to not get pulled over YOUR REAR LIGHTS ARE FAILING
they kept turning off and on, but more off than on. I have no idea if it was effecting your headlights or not
possibly your switch is on the way out or you have some chaffed wiring or a loose connection
best to check it before the boys in blue get you because I can tell you, when your lights went out you were invisible to the naked eye as it was almost dark. also best to check it incase it is chaffed wiring last thing you want is a short and a car fire.
I would of flashed you and pointed to the rear of the car however I couldn't keep up you passed me and left me for dead
