Results 1 to 10 of 22
Thread: Roof rack shade.
    Aug 2013
    newcastle
    Roof rack shade.
    Has anybody boarded their roof rack to provide shade and shelter the roof from the sun. It's hot today and Im off to rockhampton soon. Any heat reduction idea is a good idea. Just wandering idnitnhped with in can temps at all.
    Nov 2013
    Blue Mountains
    Yeah, a tarp
    Bit hard to drive with it on but
    n plus one Guest
    Quote Originally Posted by voltron View Post
    I run a 2.8m Hannibal roof basket which blocks ~ 50% of the sun on the roof. On top if this I run a 2.1m hard shell RTT plus my MaxTrax so I'm basically have somewhere in the order of 90% of the roof blocked.
    Fair to say that, in combination with tinted, near vertical, windows means the truck is normally pretty cool inside.
    Aug 2013
    newcastle
    Guess it's worth doing then.
    Cheers guys.
    Brisbane, Queensland
    My next roof rack would have alloy checker plate either in strips 300mm wide or a whole sheet with tie down rings.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Aug 2013
    newcastle
    Quote Originally Posted by rar110 View Post
    Good idea. I never thought about checker plate . I just bought 3mm black Perspex .
    redrovertdi Guest
    I think it makes a difference, also good for loading up and as a viewing platform, keeps it cooler in the back but large perspex sunroof/escape vent over the front lets the heat it
    Aug 2013
    newcastle
    The Perspex isn't transparent if that's what you mean but I just got to Rockhampton this morning and it seems to be doing a great job after sitting in the direct sun for a few hours and the car was like having sat under a tree.
    Glad I did it before I came.
    Apr 2007
    I have a full length roof rack, completely covered with a 9mm marine ply sheet - painted white both sides. Combined with a white Land Rover, tinted windows, blockout screens on the rear gull wing windows and rear passenger windows, we travel in 30-40 degree with the a/c on low or medium at most, with the vent in the "demist" position, and even then the missus turns the a/c off often as she is getting cold
    Aug 2013
    newcastle
    I also put a 40mm Eva foam partition up between the backseat and load space. This also reduces the air cons workload. I carpeted it to make it blend with the interior. I imagine it's much similar to the 130 in cab space it needs to cool down.
