Results 1 to 10 of 14
Thread: What is this?
    What is this?
    I have asked people in the trade but no one knows. Anyone have any idea what this is? I can tell you it connects to a non pressurised hot water system. Can I just put stops on the pipes and remove it? Cheers
    Jan 2013
    Penrith
    Sorry mate have no idea, I was curios so I uploaded the image to google for it to search and it came back with this, pretty close I think ... lol
    Jul 2012
    ferntree gully australia
    Hi mate , I'm not sure what you are asking , If It is the male stub sticking out of the cylinder on the left . What are your plans to put It back together ?Providing It's not the outlet , then yes you can put a cap on It , I would think that there should also be a male stub the same size lower down , If so that will also need a cap . They look to be 1inch BSP. Some tanks have two outlets ,and two inlets . Some not many have a facility for heating by boiler , this could also be what there for .
    Firstly I want to remove it, that should not be too hard. But I would also like to know what it is. Its in a small laundry, has hot water cycling through it (seemingly), does not seem to have a radiator as I thought it could be some sort of room heater to dry laundry. And it looks to be about 50 years old. It has a handle very much like the old kelvinator fridges with the winglett design. It also has a tube you can lift out, the tube has a series of round disks about the size of a cd and about 5cm apart each with a hole with radius of about 3cm and these holes are all offset. Its all very strange and I am very interested to know what exactly it does/did in the old days.
    Back down the hill.
    A water softener?
    Oct 2012
    FNQ
    Looks like an old kero water heater
    Quote Originally Posted by Ancient Mariner View Post
    that could well be it, perhaps before the days of electric hot water, maybe it heated the water and over time warmed up the whole storage tank
    Oct 2012
    FNQ
    Quote Originally Posted by F4Phantom View Post
    Used to be a rectangular copper fuel tank in recess in the end, probably long gone for scrap
    actually I took that out for the photo, thats what had the handle, but I dont think it was a tank, it was hollow
    Oct 2012
    FNQ
    Tanks usually are
