Results 1 to 8 of 8
Thread: Camper trailer tyre pressures
    Hi there
    I have new a single axle camper trailer which weighs fully loaded probably around 1.5 tonne. It has large LT AT tyres on it. I would have thought for on road towing it should be around 42PSI. The tyres are rated for maximum 51 psi.
    When I checked the tyre pressure today which were for the manufacturer they went off my pressure gauge at higher than 60 psi?? I didn't think that sounded like a good idea so I dropped them to 42
    What pressures would you run on a camper on road?
    Feb 2005
    Quote Originally Posted by AnD3rew View Post
    Hi there
    I run around 35psi
    May 2003
    On The Road
    The 60 psi would be what was needed to seat them on the rims,,
    Apr 2011
    Dungowan
    onroad about 20psi....but trailer is only around 500kg and running 185R14LT tyres.
    Jul 2007
    Pilbara
    My camper is 800 kg up to 1000 fully loaded. I run 22-26.
    Rick.
    Jul 2011
    Yarrawonga, Vic
    get some chalk and draw a line across the tread.
    go for a short drive on a smooth road / carpark ext , 100m will or so
    check the line ,
    if its faded in the center tyre is over inflated
    if its faded on the outside tyre is over inflated
    if its even across the pressure is fine and would be the pressure to use on sealed roads for the load as tested. accordingly lower pressures on dirt
    method works for car as well.
    Ahh that explains it, must have forgotten to drop them back down
    Mar 2010
    check the line ,
    if its faded on the outside tyre is under inflated
    Corrected in red.
    Ian
    D3 with extras
