Thread: Silly and simple lift question
    Caboolture
    Greetings all,
    Ok for the simpletons like myself, whats the difference between a suspension achieved lift and a body lift.
    Mick
    Jun 2003
    Launceston, Tasmania
    A suspension lift lifts the whole shassis and body.
    A body lift puts spacers under the body, lifting the body. but not the chassis. So you get better departure and approach angles, but no better underbody clearance.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Caboolture
    Ahhhh shank you masta,
    Groovy so if I just wanted to whack a decent set of rubber under the disco a spring lift would do the job. Does anyone know if 275's will fit under the standard disco or would there be cutting involved.
    Mick
    RR5L Guest
    Mick
    Gday Mick,
    If its like a rangie, im guessing your going to need to do both a spring and body lift. I did a 2" spring lift on my 92 rangie to fit 245*75*16 rubber under it, I noticed that when the wheels are articulating particularly at the back although it clears the guard arch its not by that much. 275's would probably rub.
    RobG65
    Melbourne, Australia
    Hi Mick,
    Which Disco do you have?
    If you have a Disco I, the answer to your question can be found at www.discoweb.org
    and if you have a Disco II, the answer is on the www.disco2.com website.
    Lawrance :wink:
    Bracken Ridge, Qld
    Tempestv8 you are a veritable FONT of information. 8)
    Stick around matey, you'll always be welcome with them kind of smarts !
    [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Tee heehee VladTepes,
    Thanks for the vote of confidence. I shall pop in here a lot more often and chat with other like-minded Land Rover fans. [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    tempestv8
