Results 1 to 6 of 6
Thread: The Land Rover Wheel Brace
    Jul 2012
    ferntree gully australia
    A couple of weeks ago , there was a question about the factory Land Rover Wheel Brace ? Now I have a Snap-on beaker bar with a 1 1/4 socket that I would have had for 30 plus years . This has always lived in whatever Landy I've owned . This got me thinking about the factory wheel brace , has anyone found anything else they could be used for ? cheers jimr1.
    in the wild New England, NSW
    Sounds like a good set-up ....
    ...but I think you'll need 1 1/16" SAE or the equivalent metric socket (27mm) for wheel nuts on Series 3/Deefer/Disco 1 etc.
    As for other uses for the factory wheelbrace I'm sure there are some (not necessarily related to he vehicle).
    As for the 1 1/16" (or 27mm) socket and bar - on my 110 it is the bellhousing plug, on my D1 it is the crankshaft pulley.
    Davehoos Guest
    ended up with 2 in the boot of my falcon as they fit the tow ball and trailer jockey wheel..
    disco 2 was slightly larger to allow for the chrome wheel nut covers.
    Feb 2011
    Traveling Aus
    recently lost my wheel brace for the 130.
    luckily I worked out it was missing before I got a flat or something as that could of been quite interesting.
    I then found out how hard it is to find another wheel brace to fit the 27mm nuts...
    ended up with a big long breaker bar and 27mm deep socket.
    ended up being quite a expensive thing to loose
    Mar 2012
    Armstrong Creek, Qld
    Ours worked perfectly in despatching an Asian gecko I found in the back of the D1 to Nirvana.
    Jul 2012
    Quote Originally Posted by 87County View Post
    I stand corrected , It is an 1 1/16" I don't know why I just had It , It was 1 1/8" I don't look at the socket size I just use It as I know It fits , never to old to learn . cheers jimr1 ..
