 Originally Posted by
86mud
				HI all
I have a 186 in my 109.  Which water temp sender do I need that will work with my standard  Landrover dash gauge?  There are a few different types to chose from depending on ohms....
 I just went and got a standard 2.25 engine temp sensor. You might need an adaptor, so that it fits in the original 186 location (Usually on the thermostat housing).. I replaced my voltage regulator as well, and it seems to read a little higher than it should.. I might have to readjust the regulator. (Fuel gauge is out a little too..)
Wolf
				1972 - S3 LWB (109) Wagon - Parts
1974 - S3 LWB (109) Wagon - Jess - (Registered)
1975 - S3 LWB (109) Wagon - Parts
1978 - S3 LWB (109) Wagon - Parts
1979 - S3 SWB (88) Utility - Aurora (TBR)
2014 - Defender (110) - Cher (MY15)
