Results 1 to 10 of 17
Thread: To run cables or not??
    Feb 2005
    We are nearly ready to pull the cables for our down stairs reno........there are two TV points, an open office and a bedroom.
    I am running coax the TV points....
    Should I run CAT6 to where the TV points are as well?? ie tv that can connect to the internet if I ever buy one
    Should I run CAT6 to the bedroom??
    We currently have wifi off the modem which meets most of our needs however the kids reckon plugging a PS3 into the internet is better/faster than wi-fi ie online games??
    Just figure it might best best to run cables while we have the chance...might not use them right now or is everything done via wifi these days
    Thoughts.......
    Jul 2007
    cable. Saves on WiFi repeaters to get over poor speeds etc.
    Go and speak to the electrical cable retailers and ask them what is being put into premises these days.
    Quote Originally Posted by benji View Post
    Maybe we're expecting too much out of what really is a smallish motor allready pushing 2 tonnes. Just because it's a v8 doesn't mean it's powerfull.
    One answer REV IT BABY REV IT!!!
    Nov 2011
    When I put in more tv antenna points around the house (1 to each bedroom) I also ran in 2 x cat 5 to each point as well, and also did 2 x cat 5 behind each of the existing points as well as I have devices that use the internet as well.
    Currently these run on wireless but you get much better performance over wires than wireless.
    If you have access I would run connections to anywhere you think you may want one in the future as the cost of the cable is negligible compared to having to try and do it later.
    You should check the difference in price between cat 6 and cat 5e as both will most likely do what you want (cat 6 has slightly better specs and better resistance to crosstalk so may only be better if you want a really long run) and if cat 5e is significantly cheaper should be considered. I went cat 5e when I did home as I picked it up from a wholesaler for less than $50 a box, compared to cat 6 at the time was heaps more expensive.
    Wifi I found is good for when you want to be mobile or for quick connectivity, whilst a permanent device is better on fixed. Depending on where you live and who else is using wireless around your wireless may not work real well (I have seen this lots of times in my work). If you do want to run wireless buy a purpose built Wireless Access Point which has diverse antennas, and will allow you to mount the Access Point in the best location even if its not where your internet is, the one I currently got can be powered via Poe which is very useful as well. I also installed quite a few for work and they were far better than any of the low end ones and not that much more expensive.
    Richard
    Nov 2011
    I went and had a look for the Access Points I was installing at work and these are the ones (not that I have bought them from here):
    Ubiquiti Unifi AP Wireless Access Point UAP 2 4GHz 802 11N UAP | eBay
    We used to buy them in 3 packs for about $400. These allow you to place multiple point around the office/home and use the same wireless setting in each one and it will pick the best access point.
    If you go to there web site you can download the management software, and if you have a scale drawing of your place it will allow you to place the location of the access point on it and it will give you a good indication of the coverage.
    I found that these will go through floors quite easily if you have 2 stories and have a good coverage zone.
    I would personally still run cables and use these for mobile/casual access.
    Richard
    Western Victoria
    Yep, run two cat 6 cables to the TV points. One for the telly and one for another device such as gaming console. The bedroom could be adequately serviced by wireless but if it's easy to run a cable, why not.
    May 2009
    West Gippsland - Victoria
    At the risk of stating the 'bleeding obvious', for TV and Ethernet all cables must be run from a central point and not looped point to point as is done with the AC power wiring.
    This is not in any way to infer you don't know this Weeds but a casual reader may be unaware of this.
    Deano
    PS. Don't run either of these cables through the same holes that carry power, bad for interference and safety. Also illegal.
    Apr 2011
    Wandong,Victoria,Australia
    Personally I always run cable instead of Wi-Fi. Yes Wi-Fi is great, but you will always get faster, more reliable speeds via cable...
    Yes I would run cat 6 to all of the rooms - you never know what you might want to do in the future, and it's much easier to run cable now rather than later...
    That's just my 2 cents worth!
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    Western Victoria
    Quote Originally Posted by DeanoH View Post
    Do you know which specific standard or regulation covers this?
    Adelaide SA
    Quote Originally Posted by Mick_Marsh View Post
    Cant remember the actual Standard, (AS3000 maybe) but, from memory, there has to be a minimum of 300mm physical separation between power & data.
    This also applies for mains voltage, and low (think 12v) cables.
    So, make sure you plan your cable runs, as the electrician that does the final connections wont, or shouldn't, pass it if it doesnt meet the regs.
    I'd run the CAT6 cables for sure while you have a chance.
    Having said that, I've just built a new gaming PC for No2 son and put an "n" dual band wireless card in it ($45) to match the "n" wireless router they have at their end of the house. The connection speed is 300mbps! The best you get from the CAT6 is 100 unless you've got a gigabyte router.
