yes they are difficult to move against the spring pressure. the beauty of the td5 is it will tell you if the wastegate is faulty, it'll either be extremely gutless, or go into overboost protection. another area of cause is the wastegate controller, an electric solenoid valve that can and does fail, causing faulty wastegate symptoms. defenders don't have one.
the wastegate actuator itself rarely gives problems.
jc
