Thread: High beam adjustment on 02 RR HSE
    marshy85 Guest
    Hi there i am chasing how to adjust the high beam as i have had a look and can only find adjustment bits for the driving lights can anyone help.
    Mar 2007
    Marshy
    I hope this helps !
    Laurie
    Attached Files Attached Files
    marshy85 Guest
    cheers laurie
    I will give it ago tonight
    Aug 2010
    Sunbury, VIC
    I've found I can't get the high beam where I want it - using those adjusters I can set the low beam correctly, but this leaves the high beam too low. If I set them so the high beam is where I want it, then the low beam is too high and I get flashed by other vehicles. I see no way of adjusting the high beam separately - please let me know if I'm wrong.
    Dec 2011
    Toowoomba
    When I first fitted the high and low beams HIDs, I had one bulb not "square" and it threw that beam out of vertical alignment. Prompt and easy rectification.
