Results 1 to 6 of 6
Thread: 2010 Defender Snorkel
    Jan 2008
    Goonellabah N.S.W.
    Hi, I,ve been quoted $530.00 to have a Safari snorkel supplied and fitted to our Defender. Just a few questions, is the Safari snorkel well regarded and secondly does the cost to supply and fit sound reasonable.
    Perhaps a member of the forum can provide some input.
    Thanks, Jim
    Feb 2012
    Canberra/Melbourne
    In my opinion the Safari snorkel is the best way to go. Make sure when they fit it they make all the connections Air/Water tight. See Nugget on here for a kit if they can't. I have the original LR Raised Air Intake. It is not sealed when fitted. The LR one costs about $1000
    [SIGPIC]
    2012 LR Defender 90 (BERT) Gone
    2012 Husqvarna WR 300
    2014 FPV F6 Gone
    2005 D3 SE V8
    2011 D4 V8
    2016 Moto Guzzi California Audace.
    May 2011
    Newcastle, Hunter Valley, NSW
    Check out my UK supplier http://www.lrparts.net they have snorkels at about half the cost you can get one here.
    95' 110 Defender
    58' 109 Ex NSWFB SerII
    50' 80"
    Sent from my iPhone using AULRO mobile app
    Jun 2011
    Berowra Heights NSW
    LR raised air intake is just that a raised air intake and is not a snorkel.
    Safari or Mantec are the best ones IMO, supply and install around $500 is normal pricing.
    Ebay has cheaper snorkels but quality I could not comment on.
    May 2013
    WA, South East
    Never had a problem with safari's across three makes of cars. They are as good as anything out there in my opinion.
    Trundle
    austastar's Avatar
    Jul 2009
    Hobart
    Hi,
    it is doable at home following the instructions that come with the kit.
    Only a few small holes to drill - no major panel cutting.
    Do use the recommended sikaflex compound for jointing. I used food plastic bags as gloves to apply the goop to the joints, and found by using once and discarding all the time I could keep myself and the working area clean.
