Results 1 to 10 of 17
Thread: Dodgy parts - sign of the times or just a D1 thing???
    WA
    I have rarely experienced parts which have catastrophically failed in many years of 110 and series ownership, however since purchasing a D1 I have experienced:
    A new viscous fan hub which lasted about 3 weeks.
    Valve lash caps which were not hardened and lasted ~500 km.
    The worst items though were the clutch and pressure plate I just removed. The parts were installed by the PO just before I bough the car. The parts were like new - full meat on the clutch and machining marks still on the pressure plate, however:
    2 clutch springs were broken.
    The ring tensioning the diaphragm spring on the pressure plate was broken.
    Is the proliferation of dodgy parts just due to the D1's popularity, or is this becoming increasingly common in others' experience too?
    Ben, are these parts Genuine LR, or AM?
    South Yundreup,WA.
    Ben as said were these genuine or aftermarket.
    A mate of mine had 3 Viscous fans in a row fail for a 100 series cruiser over a period of 2 months.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    WA
    The clutch and pressure plate had no markings at all. I used Britpart replacements which looked much better quality (surprisingly).
    Lash caps were genuine.
    Cannot remember what make the first fan hub was.
    This is my GUESS, and a big uninformed GUESS at that.
    When a car is in production, it would seem the maker of that car have reason to stay on top of part quality from their suppliers. Probably even for a few years after end of production. Anything after 3 years, they really don't have an interest other than legal obligation to supply parts for the minimum required time frame. I would guess that if a supplier said to LR, we can make that part a little cheaper by changing x, y or z, they may be interested. OR LR themselves may approach part suppliers.
    AM parts, from the get go, will be a wide range of quality.
    As time goes by and the $$$ value of the vehicle reduces, it would seem less logical to invest dollars, by the parts manufactures, as us buyers are less likely to spend $$$ on more expensive parts.
    On top of all that, you have the huge move to production in China. Yes things have been made there for centuries, but consider the D1 was in the late 90s and that its only been the last 10 years that every man and his dog has set up or out sourced production over there. IMO QC is very hit and miss and ethics do not exist as we see them, so many parts get small changes (materials, fit, finish, spec etc) that the part supplier wouldn't know about until in their hands or failing in cars.
    St Helena,Melbourne
    4.28 MB
    Since a TDI defender shares a lot of parts with a tdi disco it would come down to the quality of the parts used as mentioned on the previous posts, some Britpart parts are ok - my ps pump is fine after 3 years touch wood.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    sheerluck Guest
    Arrow
    I had a very similar experience with parts for my D1. Some parts did not even survive the initial torquing up, or first use.
    Mar 2011
    Cooktown, North Queensland
    Angry Not so new.
    The replacement Tdi valve lash caps issue is not a new one, I recall, 10 years ago a mate had a set done by a Land rover dealer whilst having the Timing Belt replaced, the new caps let him down 500 klms into his post retirement around Australia trip. Land Rover at the time claimed it was "just a bad un-hardened batch that slipped through", I guess that could be true, but there seems to be more "dodgy" stuff about these days and not all the cheap to buy stuff.
    I guess information sharing of bad experiences is really the only way the consumer has of finding out "pre-purchase", unfortunately we may only start checking up after the event, then we can only regret the purchase, the money has been spent.
    Oct 2003
    Godwin Beach Qld
    All the replacement parts I use on our 4 Landys are either genuine, or Bearmach,had to many Britpart parts fail on my friends vehicles to use them on mine.I have also purchased parts from Repco outlets and have asked for Genuine or Bearmach and got them
    Note on 300TDI D1's and I think Defenders, if the belt tensioner is worn and throws the belt out of line (belt powder on alternator) then it may have a flow-on effect to the fan pully.
    Feb 2012
    Parkdale, Melbourne
    Had my D1 4 years and never had any of those problems! When it comes to engine/mechanical parts though, I tend to buy whatever the internet tells me is the best quality, which for almost everything is genuine. Clutch, lash caps and fan are untouched since I bought it.
    I've replaced a head gasket, wheel bearings, timing belt, PS pump and radiator hoses since I bought it. No failures on any of them yet.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
