Results 1 to 10 of 12
Thread: More Fuel Pump Chat
    Jan 2013
    Penrith
    More Fuel Pump Chat
    Just wondering is any has experienced any improvement in performance at all after changing out a failing fuel pump.
    depends on how it was failing, yes.
    sheerluck Guest
    Quote Originally Posted by Kevin B View Post
    Absolutely. Mine would run constantly, instead of stalling at traffic lights, get out, bang the bottom of the tank, get back in, ignore horns honking, restart it....
    Feb 2011
    Denmark Western Australia
    Mine had more power on gas, and when I fitted the Bosch pump it's now got more on petrol
    VIC
    I'll let you know when I swap out my very noisy dying one laster this week
    Jan 2013
    Penrith
    Quote Originally Posted by B92 8NW View Post
    Thanks ill do the same swapping out mine early next week, it was not really noisy it just failed
    Jan 2013
    Penrith
    Quote Originally Posted by Gary S11 View Post
    Internal bosch like the original or external ?
    Crafers West South Australia
    A fuel pump is a device for keeping up the fuel injection pressure in the fuel rail. Once a fuel pump flows enough fuel to run up to the fuel pressure regulator setting it can't increase performance. If a worn pump or blocked filter prevents you reaching full pressure under full load your performance will suffer. A bigger than necessary pump won't make you go faster unless you alter the rest of the system to use its abilities.
    Jan 2013
    Penrith
    Thank Bee Utey, i kind of knew that, my question was more aimed at a faulty pump not delivering enough fuel, which you answered, thats what I suspected with mine, it had been failing for a while till it finally gave up, I guess ill see when I change it next week if there is an improvement at all.
    Feb 2011
    I think my change in power was that mine kept going to limp home mode each time I'd flick from petrol / gas etc. as via bee- utey's help I altered the wiring and this was done at the same time as changing the pump...because it sure runs better now .Gary
