Results 1 to 6 of 6
Thread: high fuel consumption
    warnie100 Guest
    hi guys I done a trip over the xmas break and found my fuel consumpson has gone to 21 ltrs per 100 klms while doing between 100/110 per hour I have been reading here and they say that increasing the advance on timing to 10deg below helps when I disconnect my vacume advance line nothing happens the timing light doesn't move when I reconnect it any ideas please
    Jul 2011
    Yarrawonga, Vic
    Quote Originally Posted by warnie100 View Post
    connect a hose to the diaghram and suck hard on it while your checking the timing, if it dosent move then your problem is in the distributor.
    Crafers West South Australia
    The vacuum advance port on the top of the manifold can block up with carbon. It only supplies vacuum when the throttle is above idle. Hold the engine at approx 2500 rpm and put your finger over the vac port on the manifold. If there's no suction, poke it out. If the vac capsule is buggered there's a cheap one available from the UK., I've sold quite a few of them to customers. They are quite easy to change as they slide in and connect to the pickup plate with a simple pin in a hole, no circlips or anything.
    Ebay link
    Setting the timing to 10 degrees BTDC seems to work well on the D1.
    warnie100 Guest
    thanks
    thanks : tried the hose bit sucked till blue in the face nothing changed so any other help such as what could be wrong would help thanks again warnie
    warnie100 Guest
    re vacume
    Ebay link
    thanks for that ideled it up a bit to iguess 2000 and the little hole on the inlet was sucking so I guess it is the vacume thing you said you have sold a few do you have one and how much thanks again warnei
    Your vac advance is broken/stuck...
    A specialist is the easiest method and they have the gear to really sort the curve as well...
