Results 1 to 10 of 14
Thread: 98 110 steering box spline movement
    Dec 2010
    cairns
    hi all was hoping someone could tell me if there is supposed to be any movement in the steering box spline on my98110 defender300tdi. I thought it was the pitman arm joint, turns out there is slight play in the steering box spline side to side, feels like a clunk when you turn the steering side to side cheers.
    Geelong, VIC
    Do you mean between the universal joint and the input spline for the steering box itself?
    Shouldn't be any movement, but I've had that steering shaft spline flog out on both my County and my old D1.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Somewhat North of Cape York...
    I have had the same trouble. As far as I know, the play can be adjusted/tightened to a certain degree, but if that doesn't help it will have to be swapped. That's what I am in for...
    Johannes
    There are people who spend all weekend cleaning the car.
    And there are people who drive Discovery.
    Dec 2010
    cairns
    spline movement
    Quote Originally Posted by steveG View Post
    Steve
    hi steve its movement in the spline that goes into the steering box if I grab it I can move it side to side slightly cheers
    Geelong, VIC
    Still not sure where you're getting the movement.
    There's the input shaft that goes into the steering box. It has an external spline on it.
    Attached to that is the internally splined part that is the lower bit of the steering shaft universal.
    Are you getting play between those 2 parts, or is it the input shaft itself moving side-side in the steering box?
    Steve
    Dec 2010
    cairns
    input shaft
    Steve
    hi steve its the input shaft into the box movement cheers
    85 county is offline AULRO Holiday Reward Points Winner!
    Sep 2010
    adelaide
    Quote Originally Posted by mudder110 View Post
    so this is the shaft from the steering wheel or the shaft with the pitman arm??
    Dec 2010
    cairns
    shaft from steering
    Quote Originally Posted by 85 county View Post
    seems to be leaking from the shaft to steering wheel spline seal not enough to mark the ground but there is a slight bit of float from the spline the pitman is on not sure if its a urgent fix or not? cheers
    Sep 2010
    adelaide
    You mentioned in a post before that there was some movement. Now you say float. Float is when the shaft will move in and out or is the a bit of slop IE it can move from side to side.
    pre-empting your response i take it that you are not that mechanically minded, that a box rebuild may be out of the question. but how would you be at swapping out a seal or swapping out the box?
    Dec 2010
    cairns
    Thumbs up shaft movement
    sorry should have been more clear, the shaft with the pittman arm on it moves slightly from side to side with the wheels facing straight ahead the the spline from the steering has a leak from the shaft seal just drove from Brisbane back to cairns it steers fine no noticeable power steering fluid loss on the dip stick but a film around the seal hoses seem fine thanks for your time. have done head gasket p seal and other stuff myself if a pump kit is available I would give it ago cheers
