Results 1 to 10 of 12
Thread: body lift kits
    melbourne
    body lift kits
    Hi guys, looking at getting a body lift. Now i know you can do the kit yourself for like $100 but i was more interested in an engineered kit like lra's white tiger kit. They seem to be the only people who have a kit which is engineered. Are there other kits around which are engineered ?
    cheers Joe
    May 2006
    Woolgoolga
    Not that i'm aware of. You definately pay for the lra kit, but it is a good bit of kit. I have one in my lse
    St Helena,Melbourne
    4.28 MB
    Maybe Scorpion might do a kit but AFAIK the LRA kit is the only one that is engineered.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    melbourne
    Thanks guys i was thinking the same, but with the laws on lifts now makes it hard for us. Not sure i think if you hit some with 35's or even 33's (depending on body lift)on , the insurance company will pull out on you due to been higher then the 150mm and not engineerable
    Narre Warren
    You'll get away with a true 32" tyre without a lift but bigger than that requires a body lift. I'd advise going the LRA one as that is a comprehensively designed and engineered kit.
    Then again I'd only go that way if you feel you really do need to run 33"+ tyres.
    melbourne
    Ok lets say i want to fit 285/75 r 16 ( just under 33 inch ) what is the minimum i need to do to fit this size tire ? flares with a 2 inch suspension ?
    As the more i think about it do i need 35's ( had them before ) i got twin locks to go in so it is only gaining 25mm extra diff clearance with 35's over 33's.
    Jun 2010
    Karratha W.A.
    I got my body lift kit from xpajun off road in the uk used them twice now they do a complete kit except for bumper brackets. Highly recommend them they do a kit up to 4.5 inches a bit over the top ha ha.
    melbourne
    Thanks Nigel i noticed the xpajun kit doesn't have the extra bracing back to the chassis for the lifting blocks, i am guessing they are important if you hit something at a 100kph. also just noticed i will have to disable my SRS Airbags ? wonder why as i would have thought they still would have worked as they are mounted behind the lights.
    West Victoria
    Body lifts are illegal on SRS equipped vehicles.
    LRA have a 4" suspension lift kit for vehicles like yours.
    Neale
    melbourne
    Smile
    I dropped by LRA today and spoke to the chap down there, as mine is a 98 with only drivers side airbag i can disable it and either remove the bag from the steering wheel or replace the steering wheel. As my model the airbags is an optional extra so by removing it i can legally fit the body lift kit i was informed.
