Thread: Window anti-trap feature
    Aug 2009
    Orange, NSW
    Oh Brains Trust!
    My D3 has an annoying issue where at speeds greater than 80kph the drivers window will re-open on closing in 100% of cases. I assume there is a pressure issue or similar that fools the system into thinking the it has trapped fingers etc. and re-opens.
    I can "inch" (or the metric equivalent) it closed but it is a bit tricky and not the point really.
    Other windows operate fine....just mine (of course)
    Cheers in advance.
    Sep 2011
    Central Tasmania (formerly Adelaide Hills)
    I am guessing the window needs calibrating again. l think you will find the method for doing this somewhere in the manual. I did this myself once when my window stopped "one touch closing". All that was required was to close the window and keep holding the switch up for several seconds (about 10?). Give that a go or check the manual for details.
    NSW SW Slopes
    Have you tried re-establishing the closed limit by closing the window then presssing/holding the up switch again for a couple of seconds?
    adelaide
    you could also try spraying a bit of silicon spray into the glass guides (not on paint) this can relieve some tension.
    connock
    Aug 2009
    Orange, NSW
    Well Done Guys. I didn't know about the recalibration. I try that first and some silicone too.
