7th January 2014, 09:47 PM
Bosch Platinum iR fusion plugs
Hi
I was looking for some WR7KI33S platinum plugs and they seem to be in short supply in OZ.
Since I am going to the US soon I started digging around and found these.
Platinum Ir Fusion Spark Plugs
I was wondering what they would be like in the P38 on LPG?
Steve
7th January 2014, 10:05 PM
No good unless you can adjust the gaps. You can also try the 5/8" hex plugs, some P38's I see have those fitted. That part number would be FR7KI332S. I've had the WR7's on back order for 2 months now and have used the FR7's instead. Just need the correct plug socket. You can also use the BA/BF LPG plugs, any brand, from memory the Bosch ones are FR7KPP33U, you just need to adjust down the gap.
8th January 2014, 08:38 AM
Hi
When i replaced the plugs a few months ago, the new ones were a different sized socket to the old ones, and they both fitted fine
Steve
