Hey Matbor,
it sounds as though you have noisy hydralic lifters.
If the oil you are using is too thin - causing the lifters to bleed down while the engine is switched off, the lifters are worn or the engine's oil pressure is low - it can take longer than normal to fill the lifters full of oil on start up. This will cause a tapping / knocking noise. This noise will normally be isolated to the top half of the engine.
It may pay to check the engine's oil pressure and possibly try running a slightly thicker oil.
