Thread: Converting stake nut to locknut
    Apr 2013
    Hi all.
    I am going to be converting to oil fed bearings and in the process I want to convert to the 'traditional' lock nut on the wheel bearings, can anyone confirm these are the bits I need?
    FTC5241 x2
    FRC8700 x4
    FTC3179 x2
    2002 defender
    thanks
    Jun 2008
    Drouin East, Vic
    Sorry I can't help with confirming the actual part numbers, but I did this with my 2008 130 last year, I got the bits from Triumph Rover Spares in SA (after going through an online order form from the UK and ending up with some of the wrong parts). I haven't dealt with them (TRS) much, but the bloke I spoke to on the phone was able to tell me exactly what parts I needed when I told him what I wanted to do. Might be better than ordering parts by number and hoping they're the right thing.
    Apr 2007
    Jabiru, NT
    HAve a look here,
    Land Rover Defender TD5 Wheel Bearing Conversion Kit with Bearings/ Seal | eBay
    All the part numbers are listed......
    Apr 2013
    thanks for your help guys
    Palmerston NT
    Quote Originally Posted by Duarte19 View Post
    Could someone let a numpty know what you would be changing with this and why?
    So this means the diff oil would lubricate the bearings instead of grease?
    astoltz Guest
    Apr 2013
    Quote Originally Posted by djambalawa View Post
    correct
    Defender Oil Fed Front wheel bearings. What is involved
    Fitting upgraded Axles, CVs and converting to oil lubed hubs
    some more info above
