Dry? The only way it could be dry is, the seal has leaked and the oil has not replenished itself from the ball. If the seal has leaked you could look for signs of a leak. If the swivel balls are not filled with oil but grease then you may have trouble replenishing the oil.
On the front I believe that there are two seals between the diff and you wheel bearings, one between diff housing/axle tube and the swivel ball and then another on the other side of the swivel ball. Work on your diff May have replaced these seals therefore stopping the diff oil from getting to your bearings.
  Reply With Quote Originally Posted by benji
