Thread: Which holley - 330 or 350?
    Hi all
    now I am at the stage of getting the most out the 186. I have ordered a high volume oil pump and will modify the sump to overcome the oil starvation issues.
    The carby is currently a stromberg and I would like to go to a Holley...but which one?
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Brisbane, Inner East.
    Quote Originally Posted by 86mud View Post
    Hi all
    Get a small four barrel manifold and make an adaptor plate to use a Quadrajet's two primary throats only. Absolutely brilliant solution.
    URSUSMAJOR
    Aug 2010
    Sunbury, VIC
    Forget the Holley - that will cause fuel starvation issues on hills, flat spots you can't tune out and you'll think there is a hole in your fuel tank. If you have a 2 barrel manifold ready to go, stick a Webber on it. Smoother. Better economy and won't conk out hills.
    If as mentioned you still have to buy a manifold, find a 4 barrel manifold and go with the quaddie primaries.
    Ok.....thanks Gav....So which Webber?
    Andrew
    Aug 2010
    Sunbury, VIC
    Now that's a good question mate - we used to fit these a lot - you may need to make an adaptor plate by the way - but we used to go down to the wreckers and pull them off any car that had one - and I can't think off the top of my head which ones did....
    I'll have a think and a search and see if I can find out.
    from my research I have come across the 34ADM as the weber to suit the holden 186
    There is one ebay at the moment for $30!
    Andrew
    Aug 2010
    Sunbury, VIC
    That's the puppy - we used to pull the auto chokes off them as they were a PITA.
    $30 is what I used to pay for them 20 years ago - bargain!
    You will need a 2 barrel manifold for it, and an adaptor plate. As you can see if you google (Images) them - there are a lot out there on Holden red motors - you can see on a lot of these photos the adaptor plate needed.
