Thread: S11a Hub Seal's
    crawfy Guest
    S11a Hub Seal's
    Hmmm I know you guy's a gonna give the old sayin !!!!!!!
    It's a Land Rover they allway's leak!!!!!!!!
    But the problem I have at the moment is the old girl has sprung a leak again a the rear Hub!!!! I have replaced the Felt seal 3 times in the last 6 mths!!! Now I have oil leaking out somewhere between the Hub wheel etc!!
    I'm now starting to wonder ( As when I started the Re-build ) the previous owner had Silicone everywhere on the rear Hub's!!!!!!!!
    Should I just replace the whole rear hub's or what?? :x
    Jun 2003
    Launceston, Tasmania
    Ok, so where exactly is the oil leaking from?
    Sounds like you need a better gasket. Perhaps one of the gasket in a tube kind of stuff. Apparently the stuff for exhaust gaskets is great :wink:
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    crawfy Guest
    Hmm me think's I know where you are coming from!!! [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
    I have only noticed it getting worse after along run!!!!
    I have a tube of the stuff in the back of the old girl so I might give it a squirt and see what happen's!! [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
    Williams West Aust
    Hi Crawfy
    The no1 cause of this type of leak is a blocked or faulty axle breather,its common in all breeds of 4WD
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Oct 2003
    Godwin Beach Qld
    11a Hub Seals
    Hi Crawfy. [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
    I agree with LandyAndy on that one, clean around the breather hole BEFORE removing the unscrewing the breather clean in petrol until you can hear the ball bearing inside rattling and then replace, if the oil is leaking down the brake backing plate behind the brake shoes,then the axle oil seal is the culprit, replace the oil seal by removing the hub check the seal running ring for wear, they are replaceable, press fitting, if leaking from the drive flange joint there is a paper gasket between it and the hub , if no gasket make one out of a piece of A4 printer paper smeared with W/B grease works a treat, if the drive flange is badly worn in the splines they will leak over time, wear can be checked by seeing how much movement is in it when the flange is unbolted
    cheers Uncle Ho [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
    Dave-O Guest
    Hi Crawfy,
    My 2a had a similar sounding type of leak. Seal replaced x times by previous owner. Found to be a knackered bearing in the hub - replaced bearing, seals and the seal collar on the shaft - Presto!
    Next Job - another oil leak! [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    crawfy Guest
    Cheer's guy's!!!- [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
    Landy Andy is on the money, as I actually had time to look at it today and it appear's that the axle seal is the culprit.
    Will attempt a repair Friday week.
    Thankyou for all your advice guy's [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
