MMM what on? There are a number of different monitor's, if you like I can email you some info that I had sent to me concerning my 300tdi Disco?
Hi lance here I was just wanting to know if any one out there has had any exsperience with low level coolant monitors or engine block temperature monitors and which one they have had the best accurate monitoring with...Cheers Lance
Lance again I am buying a new 04 disco soon and I was reading Australian 4x4 Monthly and saw the add just want some peoples views and if they are good insurance for the motor
If your still there crawfy go to chat room now Lance
Having cooked an engine in the Bermuda Triangle of the Hume Highway: Gundagai (a dog on a tucker box). I am interested in this topic.
So can we post something for general consumption on this important issue.
I am aware of two low level coolant alarms and will dig up some links.
Mahn England
Ex 300Tdi Disco:
Lance again there a company Datatron Monitoring Systems www.fdrive.com.au for the coolant level.Cheers Lance
Hi
There should be quite a lot available in the way of coolant monitors/oil level/pressure etc as a lot of this sort of equipment is used extensively in earthmoving equipment.The canter truck at work even has a button to press to check the oil level(standard mitsa****y item)
Try "engine protection equipment" on google or something
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Hi
I have used coolant monitors in diesel motors on buses and they are worth their weight in gold, as the temp sender units need water in the system before they will read (no water no reading ) and to cook a bus diesel ain't cheap, they are best hooked up to both a light and buzzer
cheers [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
Is there no imput for what I think is an important issue any ideas. I think that Tec is good if it saves money. Lance
I think you're looking for something called a Murpy Switch. They are a bit clumbersome but they work well.
Adam
