Thread: Interesting Lathe Design
    Geelong, VIC
    Found this site tonight: $150, 12″ Swing, Metal Lathe/Mill/Drill | MAKE
    Its a modern take on the award winning 1915 Yeomans concrete lathe which was designed primarily as a cheap lathe for the production of artillery shells.
    This modern version is targeted as a DIY option for developing countries and I found some of the solutions to the design/construction challenges quite fascinating.
    In particular, some of the setup ideas might be useful to those of us without the luxury of a decent workshop.
    Hopefully some of you also find it interesting.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Adelaide SA
    Certainly does look interesting.
    Only issue I have, is I am running out of room in the shed to put one...
    Feb 2013
    Ballarat,Vic,Aus
    The other problem of course is the tooling. Even if you buy a heavily worn old lathe. It's likely still close enough for anything a DIY'er will make. And more imporantly will come with the tooling. Just add up buying 3/4 jaw chucks, dead/live centers tool holders, tail stocks etc....
    The hardest bit will be learning how to it once you have one!
    seeya,
    Shane L.
    Brisbane, Inner East.
    Given the low prices of Chinese hobby lathes these days, why would one bother.
    URSUSMAJOR
    WA
    Quote Originally Posted by Brian Hjelm View Post
    It is intended for the 3rd world - where they don't (necessarily) have cheap chinese imports...
    Geelong, VIC
    I agree - you wouldn't bother making one here unless you wanted a project for project sake.
    There were a few things in the construction that I thought were quite clever. One was the method of setting up the main ways and then permanently locking them in position using non-shrinking grout.
    Maybe I'm just not working in the engineering space on a daily basis, but I found it got me thinking in a lower-tech way than the usual "everything needs to be welded/machined with expensive equipment to produce a reasonable result" mindset.
    Steve
    Hay Point
    Quote Originally Posted by Basil135 View Post
    You know the answer - BIGGER shed.
    Cheers......Brian
    1985 110 V8 County
