Results 1 to 9 of 9
Thread: Clutch Damper
    crawfy Guest
    Clutch Damper
    Are there any known problem's on the clutch damper on the Disco's as I had a conversation with a mechanic (who is from the mother land)
    and said that there has allway's been a problem with the clutch damper!!!!! First I'd heard of it!!!
    Any comment's????
    Brisbane Australia
    They do fail from time to time. The clutch losses travel and won't disengage as the damper absorbs the fuild movement from the master cylinder. You do need them on a TDI or the pedal pulses with out them. V8 cars don't have them. The other main point of failure of a TDI clutch is the fork, these are pressed metal and they crack where they pivot on the ball in bell-housing. The forks are about $60, clutch kit is about $350. Factory clutch is made by "valeo" but " borg and beck " are nicer to drive.
    Mansfield, Victroria
    Hey Charger
    I put a post up ages ago in relation to Clutch kits - the 200TDI clutch is the same as the Valiant Charger clutch kit - and about $60 AU a MUCH better deal
    mick
    Brisbane Australia
    Is it the same or does the Val just fit? Falcon clutches fit Jags and Feraris but they aren't the same. As long as the clamp pressure is the same it won't slip but the driven plate springs and construction may be different. TDIs are know for shaking the crap out of driven plates. As well as different clamp some pressure plates are cast iron and some are forged to cope with high load / revs not that revs are a problem with TDI's. Have tried one and if so hows it going? I don't mind paying for something if it works properly.
    Mate - what I know is this :
    A mate of mine owns and runs a Landrover workshop. he has checked it out and found that it is correct fitment for the vehicle. That is all i can say,
    when my time comes to fit one (touch wood) I will be fitting one.
    I trust him, but as with any posts individuals need to do their homework first -you may be surprised.
    This mate of mine BTW races a disco off road - its what he runs in that too.
    mick
    crawfy Guest
    Hmm interesting, I did a search last night and found a few threads, the problem isn't as bad from what I can gather as the Timing Belt issue?
    But it's interesting to know the quirks our vehicle's may have :?
    HMMM wait till ya gotta bleed the sucker ! lol
    mick
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    only had to do one, and that was 1 to many [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
    as bad as bleeding the brakes on a series ii shorty...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Defender200Tdi Guest
    Clutch bleeding? 8O Did someone say clutch bleeding? 8O I've still got the scars...
    http://www.aulro.com/modules.php?name=Foru...ter+replacement
    Paul [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
