Thread: Timing gasket leak. New timing chain?
    Jan 2014
    Sunshine Coast
    Iv finally found 1 of the 2 leaks in the ol girl today. It appears to be coming from the timing cover gasket above the oil filter. As much as i dont want to, im thinking of paying a mechanic to replace it for 2 reasons: 1. It should be done correctly. 2. If it leaks or something else becomes a problem, well it wont be my fault.
    Since its nearing 300k km, on original motor (service history is unknown) while the timing cover is off, might get the chain done too. What do you think?
    Also would anyone have a rough price of the cost of this exercise (with and without timing chain)?
    how soon (SWMBOS car has blown budget and I need some spanner time)
    how much Growth work are you willing to look at doing at the same time?
    And whats your time frame if the growth work needs parts?
    and are you willing to drive the vehicle to its repair location?
    Jan 2014
    Sunshine Coast
    From your first sentence your offering to do the work, right?
    I dont understand your second sentence sorry.
    Quote Originally Posted by TriPolar View Post
    sort of depending on time frame and a few other things.
    Growth work is stuff that gets found on the way.
    for example pulling the timing cover means pulling the belts, if the belts are knackered they need to be replaced, thats growth work.
    essentially, How much do you want to fix while its in? or
    What do you want to spend on the repair?
    Jan 2014
    Sunshine Coast
    Ah i see. Really, just to stop the leak. Had a sit down and looking of the motor (whilst RTVing the **** out of where i think the leak is). Just a good fix will do for now, as its nearing 300k km and unknown service histroy i think ill aim for a rebuild and mild cam. Atleast that way ill know itll last the life ill have it.
    St Helena,Melbourne
    4.28 MB
    If you are taking the cover off then you may as well put a new cam in as its most likely worn.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Would rad weld be able to stop it for the time being.
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
