Page 1 of 10 123 ... LastLast
Results 1 to 10 of 99
Thread: Towing Capacity
    LandroverScott Guest
    Towing Capacity
    G'day,
    I was hoping someone can help
    What is the "official" towing capacity of a Perentie 110? can't seem to find it anywhere, checked the RPS etc etc.....
    What is the "real" towing capacity, I would have thought 3t..........
    thanks in advance
    Near Seven Hills, Sydney
    Probably 3500kg braked, one would expect it'd be the same as a civvy 110 of the same design but I can't check the numbers at the moment.
    East-South-East Girt-By-Sea
    1.20 MB
    Herman Vlothuizen in the Netherlands collects original Land Rover brochures from all over the world.
    This is the spec sheet for the civvy One Ten, note that it doesn't include the Australian spec 4BD1, but you wouldn't go too far wrong if you used the V8/LT95 110 spec.
    http://www.landrover.vlothuizen.nl/i...01/4001-17.jpg
    in the wild New England, NSW
    Hayman -Reece towbar for the County is marked 4000kg (braked), 750kg (unbraked), 180kg towball weight
    Thankyou everyone, that answers my question
    regards
    oowa Guest
    Towing capacity
    Rated to tow 900kg, later upgraded to 1200 kg, that's it unless you get it re- engineered.
    Mar 2009
    maryborough qld
    I would think the REAL towing capacity would equal or better the rr classic which was 4000kg or emergency slow short distance 6000 kg.
    Quote Originally Posted by rangietragic View Post
    Disc braked Rangie versus rear drum braked 110? I know which I'd rather try to stop a trailer with.
    oowa Guest
    Towing capacity
    I bought my perentie, partly cause I wanted to tow my car trailer, with my mb jeep on the back, bit saddened to know find out I can't just do it.
    I haven't taken it to an engineer, but I know $$$ would be involved, I am sure the Landy is capable, just not legal to do it, not worth my insurance to try.
    Bruce
    750kg unbraked
    1200kg max towed load
    as in accordance with the veh-g-100
