Check note that it wont be big enough and in a short while you will be looking for a 250A model
Best way to check it is to turn up with a bottle of gas, some clean scrap steel and a roll of wire and burn it at max setting for a while... check the duty cycle specifications and then see if it will do them without trouble.
Obviously if it lets the smoke out it fails the test but likely the seller wont be too happy!!!
But honestly check if a 130A MIG unit is going to do what you want in the first instance.
S
