Results 1 to 10 of 17
Thread: Disco 2 Recalls/defender recalls
    Pilbara WA
    Product Info: Campaign D149
    Defect details: The affected vehicles could experience the ACE (Active Cornering Enhancement) pump banjo bolt loosening, due to insufficient torque at manufacture, and allowing fluid to leak past the joint. When the fluid supply is exhausted a diagnostic warning light will be illuminated and the ACE system will go into a fail-safe mode.
    Consumer action: Please contact your authorised Land Rover Dealer.
    Product Info: Model Years 1999 - 2004
    Defect details: After use of the traction control system in off road conditions, longer brake pedal travel and additional effort may be required.
    Consumer action: Contact your authorised Land Rover Dealer.
    Make: Land Rover
    Model: Discovery Series II and Defender
    Model Years From: 1999 -2004
    Consequences: May experience a reduction in the noticed level of vehicle deceleration and an increase in the travel of the service brake pedal.
    Campaign Number: D148
    Defect details: The affected vehicles could experience the throttle sticking intermittently during operation; the exact point of sticking is not predictable and can result in a higher engine speed than expected.
    Make: Land Rover
    Model: V8 Discovery Vehicles
    Model Years From: 2003
    Consequences: In the case where a throttle fails to return to idle after a high degree of engine throttle application, the driver will experience difficulty in bringing the vehicle to rest.
    Campaign Number: D150
    Defect details: A potential abrasion condition between the front left hand flexible brake hose and tyre. The front left hand tyre can contact the hose and cause abrasion to the outer lining material which could result in a brake fluid leak.
    Consumer action: Contact your Land Rover Dealer to make arrangements to have your vehicle inspected. Work will be carried out free of charge. For further information contact Land Rover Customer Response Centre on toll free 1800 625 642.
    Make: Land Rover
    Model: Defender
    Consequences: An increase in brake pedal travel.
    Campaign Number: D273
    Product Info: Model Years 1998 to 2002. Campaign D275.
    Defect details: The handbrake applicaton may vary up to two clicks between successive applications; and The adjuster wedge in the back plate may misalign changing the brake shoes required travel.
    Consumer action: Contact your Land Rover Dealer.
    Make: Land Rover
    Model: Discovery Series II (V8 and Td5 manual vehicles only)
    Model Years From: 1998 to 2002
    Consequences: The positive action of the handbrake application may not be able to be determined by the driver.
    Product Info: 1998 to 2002. Campaign D274.
    Defect details: The throttle cable may have been damaged during manufacture, which could cause the inner cable to rub resulting in individual strands of the cable breaking.
    Make: Land Rover
    Model: Discovery Series II (V8)
    Consequences: The broken strands may prevent the throttle from returning to its rest position.
    Campaign Number: D274
    Quote the campaign number when talking to your dealers.
    Check the following link for more information.
    http://www.recalls.gov.au/
    There are two types of people in this world, good and bad. The good sleep better, but the bad seem to enjoy the waking hours
    Oct 2003
    Montrose, Vic.
    Thanks BB
    Nice to have someone doing our homework for us.. [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    .......how is your year 11 physics :?: 8O 8O 8O
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Moses Guest
    Yep, onya BB! [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
    D148 is the one where the ABS Modulator is replaced. Just had mine done during the service. 8)
    Pilbara WA
    Originally posted by Bytemrk
    Thanks BB
    Guy's you should know I am here to help
    Please forward all payments of gratitude to the usual address
    Oh and Bytemrk, dont tell the kids but I only made it to year 10 :?
    May 2003
    On The Road
    The following is attempted humour and should not be taken orally,,,
    "after a high degree of engine throttle application, the driver will experience difficulty in bringing the vehicle to rest. "
    now thats what owning a V8 is all about 8)
    Pilbara WA
    Is the only way to drive. :wink:
    Oct 2003
    Montrose, Vic.
    BB Writes
    <div class='quotetop'>QUOTE</div><div class='quotemain'>Is the only way to drive[/b][/quote]
    Are you sure.... :roll:
    What about sideways :?: :?
    Mark
    Pilbara WA
    BB Writes
    What about sideways :?: :? [/b][/quote]
    If you drive it right then sideways is a by product of the V8.
    Goes hand in hand
    May 2003
    On The Road
    sideways is good-- [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    sideways demands practise--- [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    sideways is expensive---
    sideways is easier with RWD---(compared to AWD-FWD)
    sideways becomes amazingly easy with locked diff RWD---
    Controling sideways becomes amazingly difficult with locked diff RWD---
    arhhh, the cheesey grin photos I could show you of Pedro_The_Swift
    racing the Ole" Datto,, [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img] [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    Jul 2003
    Not even a beard in full growth could obscure that grin [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
    Did someone mention a sideways smile
    Mahn England
    Ex 300Tdi Disco:
