Results 1 to 6 of 6
Thread: Series III door top sealing
    sandie Guest
    Hi all
    The restoration of Sandie approaches its crescendo! but, I have a problem: (yes, again!)
    My lower hinge mounting screws are rusted solid so I can't adjust the heights of my doors. I can slightly adjust the angle by using the top hinge.
    When I close the doors the door tops sort of "cam" outwards and open up a noticable gap between the top corner front edge of the door and the corner of the windscreen.
    Anyone got any tips on how to fix. I mean, this is a major gap that you can put your finger through!
    Any ideas appreciated
    Richard
    Invermay Tasmania
    Had the same problum with my series 3 and all i did was to pull the top of the frame and bend it in towards the frame it takes a couple of goes but will work
    adam
    Jun 2003
    Launceston, Tasmania
    Incisor pointed me t oa good one once.
    You can get a rubber channel for fly screens that is about 5mm in diameter and is almost u shaped in section. It is for holding the edge of the fly wire.
    If you take the door top off and run some along the outside edge. THen put the door top back on and it will (naturally) tilt inwards more.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Hi
    you dont need to take the door top off. just loosen it off enough to push the fly screen rubber in and then tighten it back up.
    move the rubber further in to induce more lean.
    i have mine right on the outside edge and it holds mine in just nice.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Williams West Aust
    Hi Sandie
    I agree with the others re the seals.
    To get the "big" philips head screws undone firstly order some new ones plus the "captive nut" plates that they fix to.Try to get a "unsiezer" product onto the threads where possible and leave for a few days.
    Here is a good tip use brake fluid(try not to get it on the duco!!!!!) as an a release agent,much better than any spray product!!!!!
    After a few days when the new screws turn up use a nail punch and hammer to "unscrew" the nuts,if the first blow dosnt free the screw,the second usually will.
    Goodluck
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    sandie Guest
    Door Tops
    Thanks guys. I think I have a metal fatigue problem in that I tried to bend the frame and had no real problem, but as soon as I shut the door the !#$%^ thing cammed out again.
    The door top actually wiggles on the door bottom. The top of the top has almost 3cm of movement, so I suspect the bottom of the window chanel is rusty and fatigued.
    Solution, wet legs or new door tops I guess.
    All good suggestions so thanks again.
    Richard
