Results 1 to 10 of 15
Thread: RRS drops to access height when parked
    Feb 2009
    Mt Barker, SA
    Hi there, as a newby owner of a 2008 RRS TDV8 I have noticed it drops from normal to access height when parked for more than a couple of days in the shed. Drops evenly and fires back up to normal height once started. Question is: is this an issue I should be chasing up? What have others had to do to fix this? Thanks. p.s. just slowly working through so far minor issues since buying...... hope there's not too many more as its a great drive!
    NSW SW Slopes
    Most likely a slow leak and the vehicle is levelling downwards over time. Either disconnect the battery or remove the engine bay 20A suspension system fuse to stop the levelling which may show that 1 corner drops.
    Nanny state UK...
    Finding leaks can be a PITA but if you apply a soapy solution to to the components, lines, joints, etc... It'll help you trace the leak as bubbles will start to form. Sticking it in Extended mode will help too when checking.
    M
    Feb 2009
    Mt Barker, SA
    Hi Graeme, thanks for the suggestion. Have parked in the shed today and pulled the fuse. will be there for a few days so will let you know.
    Feb 2009
    Mt Barker, SA
    OK, so parked in the shed at normal height. 3 days later with the fuse pulled the front drivers has lowered (not all the way to access yet) while the rest are fine. So, any suggestions of where I should start? Front valve block? Air line to the drivers front wheel? Or just start with the soapy water and check everything? Any options more likely than another? Thanks for the advice.
    NSW SW Slopes
    Soapy spray starting at the front valve block (it may have split at the connection), along the airline, the connection at the top of the airspring (difficult to get good access) then all over the air-spring.
    May 2011
    Orange Grove WA
    Quote Originally Posted by Marty110 View Post
    When I put my GOE emergency airup kit on, I felt that the front valve block (located on drivers side in front of the wheel, behind the lining) did not have very tight fittings. Took no effort to undo the air lines. I used locktite as specified in the kit, and I think now have a more secure connection.
    I would try there first.
    Brett....
    Dec 2011
    Forrestfield WA
    Brett, I assume this is the new non cutting GOE kit. I will have to have a look sometime. Mine is the cut the pipe type kit and I had a few leaks early on.
    bob
    Joel Guest
    Mine drops to access height within a few minutes
    once turned off my 2011 RRS drops to access height within a minute not a slow leak just drops as if someone had pressed the button to drop, I thought this was normal until I saw this post. Is there something wrong is it meant to hold its height? does this mean my compressor might be working harder to constantly pump it up to normal height. No code or errors coming up
    It is certainly meant to hold it's height.
    Are you sure it is 'dropping' height and not just re-levelling height. Re-levelling is normal after you park. Dropping height is not.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
