                                                21st January 2014, 06:37 PM
			defender td5 cuts out
					Hi guys & girls I have a defender td5 will run fine for a while then it looses all power and cuts out no dash lights at all and clock at all . then I leave it from sometime a few minutes or hours then its fine turns back to normal runs fine till it happens again at least once a day if anyone can shed some light please help me thank you Jason  p/s have replace the injector loom and main loom clean ecu was fine for about three months
                                                21st January 2014, 07:04 PM
					Check the relays under the drivers seat make sure the connections are not corroded
                                                21st January 2014, 07:31 PM
					Not sure but I've heard they may be a loom that runs round the back of the engine that rubs through, not 100% though.
