Results 1 to 10 of 15
Thread: Where do you leak?
    Defender200Tdi Guest
    Where do you leak?
    After a long line of repairs, I've finally fixed the last of my oils leaks (and yes, I know it wont last long) :roll: . However, whilst I'm enjoying my present state of clean driveway bliss, I thought it might be interesting to run a poll and find out who's leaking where. ops:
    When I bought the Exxon Valdez almost a year ago, there were 11 separate oil leaks:
    Rocker cover
    Cam pulley seal
    Crank puley seal
    Left swivel
    Left stub axle
    Right swivel
    Gearbox - remote selector housing
    Gearbox - selector shaft spool retainer
    Rear diff pinion
    Left rear hub
    Right rear hub
    They're all fixed now, and I'm waiting with baited breath to see from where the next environmental disaster will spring.
    So, what's your story, what have you done to curb or a least slow the LR automatic underbody oiling system?
    Paul [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    Jun 2003
    Launceston, Tasmania
    I leak a bit from the gearbox at the moment (I think it is the conversion plate), and one swivel housing leaks a little, both are extremely small leaks though, maybe a drip every 2 days.
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Remote South Aus.
    Leak?
    I thought that black stuff was rust inhibitor. :?: If it is my Rangie will never rust! Rangie to come off the road when i get the wife a sedan so i can fix all the leaks. Engine, gearbox, transfer case, power steering pump and fuel tank drain bung.
    :x
    Gaz
    CROMER, NSW
    most of mine are so small they don't even drip. there's only 1 that's giving me greif at the moment, the transfer case. it's leaking at a steady rate. on a long trip on the highway i find spots on my tail gate. just another job to put off the household chores for [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
    LAND ROVER;
    HELPING PUT OIL BACK IN THE GROUND FOR 70 YEARS
    CARS DON'T GET ANY "GREENER" THAT.
    Mornington Peninsula VIC
    I can live with the oil leaks - they stop the driveway from rusting...
    The one I'm worried about is the leak that leaves me with a wet right boot when it rains.. Do you think I can find it? I had the missus spray the rangy (with the hose!), while I was bum up down in the footwell... Didn't leak..
    Missus just got a job as a window fitter though, so I'll get her to bring home some sikaflex, and just keep pumping it in there till it stops! [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    Western Australia
    Paul,
    How come I can only specify one leak in your poll???
    Most RR's have more than one leak (mine included) or they have no oil.
    RichardK
    Series IV Matrix Offroad Camper following our Discovery 3 with E Diff, BAS Remap, Mitch Hitch, Uniden UHF, Codan NGT HF, Masten TPMS, Proquip Compressor Guard, ARB Winch Bar, Milemarker Hydraulic Winch, 4x4 Intelligence Rear Wheel Carrier, VMS GPS with Rear Camera,
    8) i usually leak in the garden between the pool and the lounge room, [don't tell]
    but my land rover leaks where it wants to [like our dog]
    usually front diff, aft of tfr case and the engine in small bits everywhere, and the power steering box
    some of that lubricates the underbody
    Safe Travels
    harry
    Pilbara WA
    I dont have leaks.
    Have tried to find out if I have a problem because of this, because I keep getting told "that cant be right"
    :wink:
    There are two types of people in this world, good and bad. The good sleep better, but the bad seem to enjoy the waking hours
    Jul 2003
    ops:
    My Urologist drives a Range Rover.
    He should know.
    Expedition Incontinent.
    Mahn England
    Ex 300Tdi Disco:
    Hey BB, my Defender doesn't leak oil now either .
    Don't worry though, I'm sure that in time both our vehicles will recover from this temporary problem. :wink:
    Richard...hmm, I didn't think this one out very well did I? Maybe the "most of the above" option is pretty much gets the point accross. [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img] Anyway, you don't have time to be answering polls, out with the silastic and socket set my man. You have work to do!! [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
