Results 1 to 10 of 26
Thread: Brakes, almost crashed....
    beagleONE Guest
    Hi all, just running about today in my 1996 D1 with "wabco" ABS system.
    Was slowing down coming into a busy intersection, but when I put my foot on the brake pedal it shuddered and made a rapid mechanical clunking sound. I also pretty well lost all braking capabilities, so I had to revert to using the worn out hand brake to slow me, which thankfully it did as I missed getting cleaned up by a semi by a couple of feet.
    I pretty well **** my pants
    Anyhow, I pulled over to check my fluids. And they were all good.
    So I limped straight home to start googling. Apparently ABS issues are sort of common with D1's.
    -Do the symptoms I have described suggest ABS failure?
    -Is it safe to pull the under bonnet fuse to bypass the ABS?
    -How much trouble is it to completely remove the ABS, as Im happy to not run ABS for the sake of reliability.
    Moruya Heads/Sth. Coast, NSW
    For safety's sake, if you know nothing of brake mechanics, take it to an expert, your life may depend on it being repaired properly, Regards Frank.
    beagleONE Guest
    Tis the plan Tank, definitely dont want to mess around with the anchors.
    Have the basic understanding of how to do a bleed etc, but have never tinkered with an ABS equipped car.
    Seriously considering taking it to a brake mob, getting extended braided lines and removing the ABS.
    In the meantime, will removing the under bonnet ABS fuse ensure this doesnt happen again? Or have the symptoms described elude to something else being the issue.
    Geelong, VIC
    ABS sucks on the D1 in my experience.
    Does your ABS warning light work, and if so, does it ever show a fault?
    I used to occasionally get similar issues on my D1, but I also got the occasional ABS fault which was wheel sensor related.
    Sometimes giving the wheel sensors a good push back into their carriers would sort it out for me.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    beagleONE Guest
    Hi Steve,
    I believe that the ABS light works on ignition start up (will have to double check). But havent noticed it when it has been displaying these symptoms.
    Yeah, after todays experience (if it is ABS related) makes me want to simply bypass they system as the fault is more dangerous than not having ABS.
    Where are the sensors located mate?
    Do you have to rip the wheel off to get to them??
    Thanks for your help mate!
    Jan 2013
    Mt Barker SA
    boy that is scary! hope you get to the bottom if it. ive had similar in my D2, its like it breaks traction (chunks missing in my tyres) then abs goes on, it throws my foot off the pedal and does this weird thing and doesnt stop as fast as it other wise would.
    beagleONE Guest
    So went for a quick drive around the local industrial area and tried to lock up the wheels, and engage abs to see if I could get a similar feel on the pedal.
    Got ABS to engage a little (only just, slight pedal vibration) but it was not making the same rapid mechanical clunking noise and maintained braking capabilities
    Went to TRS, the bloke was under the pump, so only got a half interested answer. He said may be the brake proportion valve, said about $100 for them to inspect and see what was going on... But I think hes off the mark there, as the rapid mechanical clunking noise sounds to be coming from the footwell/front area.
    Its not doing it consistently, which is making it hard to diagnose....
    Geelong, VIC
    Quote Originally Posted by beagleONE View Post
    Hi Steve,
    Front sensors are in the top of the swivels, and rear ones go in horizontally. They are on the end of the only thick electrical wire that runs to to each wheel.
    Its definitely different to normal ABS operation, and I've even had it in car park at about 10kmh so its not related to severe braking.
    Went to pull up behind a queue of stationary traffic and
    Steve
    beagleONE Guest
    Quote Originally Posted by steveG View Post
    Steve
    Spot on mate, so far that is when Ive had it happen to me. Low speed, randomly, generally turning left....
    Ive had no issues at high speed, yet
    And just testing it out under serious pressure (80km/h+) it brakes fine.
    I checked out the under bonnet fuses.
    Its an average picture, but visually the fuse seems in tact.
    But I did notice some 'burning' near one of the legs
    To help determine if it is ABS related, or the prop valve like the bloke at TRS suggested. Is there any danger if I were to remove the two abs fuses from in the engine bay and see if it happens again (ie, and danger of driving for a prolonged time with out these fuses in place???).
    I dont really want to spend money getting the wrong thing diagnosed.
    EDIT - Have also checked on dash brake light. Highlights 'brake' when pump fuse is removed. So works. No ABS specific lights though?...
    Have had a look at the thick electrical wires. Someone has definitely tinkered with them in the past. Different colored cable ties holding them in place
    Mar 2011
    South Aust
    Ive had the same thing happen to me twice. Both times it was just as I was coming to a stop from low speed. A quick off then on of the peddle and it was gone. Hasnt happened again but I am interested in finding what the cause was/is.
